Collapsed faces
Old   July 6, 2004, 12:50
Default Collapsed faces
Aline
I have collapsed faces. Can someone help me? Thanks
Old   July 6, 2004, 15:01
Default Re: Collapsed faces
4xF
This happens when you create prisms out of hexahedras and merge the vertices on one of the prism edges: the cell definition does not correspond to the one of a prism and is still a hexahedron. Hence the collapsed face. Run a cell check and put all the cells with collapsed faces into a cell set. Use then: CFLIP,CSET,,,PRISM (or CFLIP,CSET,,,COLLAPSE)
Hope this helps...
Old   July 7, 2004, 06:50
Aline
Thanks! It works!
PostChannel collapsed field result inconsistancy maka OpenFOAM Post-Processing 9 March 5, 2008 04:50
Problems with Meshing: Collapsed Cells Emmanuel Resch Siemens 1 July 30, 2007 03:02
negative volume & collapsed faces Tipakorn Siemens 1 March 7, 2006 00:41
how to deal with the collapsed faces limingtiger Siemens 2 July 15, 2005 06:44
Collapsed cells Julie Polyakh Siemens 1 July 10, 2003 15:41
