Error message
Old   August 31, 2004, 08:54
Default Error message
new-user
Hello Everybody,
I am getting this message. The calculation starts, but does it mean that it will not take into account the wall boundary conditions? How do I increase the NTWPOS?
*** YOU ARE RUNNING DOUBLE PRECISION VERSION *** NTWPOS: MEMORY ALLOCATED: 0 . MEMORY REQUIRED: 4
*** WARNING #122 *** INSUFFICIENT MEMORY ALLOCATED IN parm.inc TO OUTPUT WALL DATA IN .pst FILE.
INCREASE NTWPOS OR WALL DATA WILL BE IGNORED.
Thank you for your help.
Old   September 2, 2004, 11:10
Default Re: Error message - NTWPOS!!!!
new-user
Would you help me? Is this error indicating that my solution will be wrong? The model is huge, but it seems to converge...
Thank you for any help
Old   September 2, 2004, 14:15
Brian
Did you by any chance switch on the output of wall data AFTER writing the .geom file? And then not write a new .geom file?
That could cause your parm.inc to have the wrong dimensions.
Try deleting parm.inc, open Prostar, RESUME, execute GEOM and PROB, SAVE and try again.
Error message-Floating point error Vaibhav FLUENT 3 December 7, 2007 05:38
ERROR MESSAGE: line 1: parse error Lourival FLUENT 1 February 18, 2006 01:35
help on error message zwdi FLUENT 1 January 10, 2004 22:58
Error message RM FLUENT 2 January 8, 2004 06:05
Gambit 2.0 - Error Message (ACIS ERROR 1200) James FLUENT 1 May 14, 2003 08:13
