Star CD installtion on Linux
Old   October 7, 2004, 15:11
Default Star CD installtion on Linux
Samir
I need help ! I have used Fluent on windows. But this is the first time I am using Linux. Can anyone please guide me how to install Star CD on a linux machine....Thank you . Regards Samir
Old   October 7, 2004, 18:26
Default Re: Star CD installtion on Linux
CFD
Hi Samir, if you have the disks then you should have the installation guide with it. Its actually very easy to install STAR on Linux. I did'nt have any experience of Linux when I installed mine either...
Old   October 7, 2004, 23:16
samir
I do have the discs and the guide. do i have to be logged in as root to go ahead with the installation. thanks a lot, samir
Old   October 8, 2004, 03:03
matej
It depends.....but generally speaking yes. The default way of installation is for the roots. It is however much easier to ask someone around your office to help you with it and give you the basic hints of using the linux.
good luck
matej
Old   October 8, 2004, 08:47
Leo
You do not need to be root to install the software on Linux. You just need to have write permission to the directory you install it in. Read the installation guide before installing.
Old   October 8, 2004, 16:08
Sheila
But you do need to be root to install ABSOFT as it installs library fiels..glib...
Old   October 8, 2004, 20:56
Samir
Thank you everybody!!!
Old   October 8, 2004, 21:26
steve
I do not believe that you do not have to be root to install absoft. You can put it anywhere as long as your path and the ABSOFT variable are set correctly.
Which Linux for Star-cd 4.02 ? David Baker Siemens 8 March 12, 2007 03:08
star-cd on Linux Ak-47 Siemens 15 January 10, 2007 15:05
Seting up star on linux Joel Siemens 1 April 15, 2002 10:08
star-cd and Linux vittorio faluomi Siemens 8 November 2, 2000 15:40
Star and linux Caroline Siemens 10 April 10, 2000 11:39
