Can not using moving mesh in starCD of linux
Old   October 16, 2004, 05:05
Default Can not using moving mesh in starCD of linux
xhliu1
Hello everyone!
When I doing the tutorial 7.1 of starcd,I can not run the solve modoul,and on the screen, I was said ------------------------------------------------------- [root@ndtcenter-4 tut7.1]# ./star *** Using FLEXlm licensing *** ENTER A CASENAME (UP TO 127 CHARACTERS) - DEFAULT=star tut
License info: CDLMD_LICENSE_FILE=/opt/v3100B/license/license.dat (from ~/.flexlmrc)
Checking out starsolver
*** GEOMETRICAL CALCULATIONS STARTED *** GEOMETRICAL CALCULATIONS COMPLETED Could not find and execute PROSTAR -------------------------------------------------------
can anyone help me! Thank you in advance!!
Old   October 16, 2004, 10:13
Default Re: Can not using moving mesh in starCD of linux
Bhaskar
Restart the system and then run the model once again. It should work.
Old   October 16, 2004, 18:41
Jörn Beilke
If you want to do the mesh movement with prostar you need 2 starsuits in the license file - 1 for star and one for prostar.
Otherwise you have to use the newxyz.f subroutine. Ask your suport for an example how to do it.
Old   October 17, 2004, 08:46
xhliu1
Thank you for you replies!
I have restart the system,and it can not work!
Acturely, I can run prostar and star before but moving the case of moving mesh.
Old   October 17, 2004, 09:12
John Luo
It looks like that you don't have a file called PROSTAR. After exiting prostar, you need to run pmovlink which will generate this file.
Moving Mesh Run problem - Scientific Linux G. SE Siemens 2 May 7, 2008 07:15
Starcd 4.2 on Suse Linux 10.2 Abdalla Siemens 3 April 12, 2007 16:47
Can Starcd for linux run in Linux Debian? help deisler Siemens 1 February 28, 2007 04:27
about STARCD v3.15 on Linux 7.3 bv Siemens 1 July 13, 2005 04:05
Erro while running moving mesh in linux version. xhliu1 Siemens 9 November 15, 2004 09:36
