Proam cpmatches
Old   November 4, 2004, 05:59
Default Proam cpmatches
Erika
Dear all, I have some problem during the generation of a trimmed mesh because of the cpmatches errors found from the Mesh Quality Check. How can I fix this problem? I read the online help, but I could not find anything. Thanks, Regards
Old   November 5, 2004, 03:33
Default Re: Proam cpmatches
sankar
1)you can try remeshing the part with diffrent element sizes, particulary there should not be large gradient in mesh density,with grow 2 or more
2) delete cells near cpmatches and run tetfix
sankar
Old   November 5, 2004, 04:07
Erika
Thank you, I'm trying to do the second choice because I've already tryed the first one by using different Custom mesh. Thank you again! Erika
Old   November 8, 2004, 19:21
Kevin
Erika,
How did you generate the custom mesh? Did you classify using a certain cell length or did you make the custom mesh yourself. I find it strange that you have cpmatch errors in a custom mesh, if so can you fix the errors,
vset news cset vmerge vset,,.001 cpcheck,,all,,,news,,fix
The above cpcheck will fix some cp errors and put the rest in your cpset so you can look at them.
Kevin
proam errors Radhika Siemens 2 November 13, 2006 04:56
Help proam yogesh Siemens 8 February 16, 2006 05:19
proam sankar Siemens 0 February 23, 2005 04:58
Cell Quality Checks -> CPmatches Derek Siemens 2 August 6, 2004 04:36
about CPmatches Nyquist Siemens 0 May 22, 2003 04:56
