February 3, 2005, 10:50 |
resize GUI
Hi
I would like to know how to resize Star's GUI, I cannot see the bottom part, or how to move the GUI window when the mouse arrow scroll down. On my previous computer (bigger screen) I had no problems but in a laptop things are different. Thanks CM |
February 3, 2005, 11:07 |
Re: resize GUI
You have to locate the mouse to the side of the Star's GUI. Then click on the right button of the mouse. Choose Size and you can resize the window.
You can also use Alt+F8 Stephane |
February 3, 2005, 12:04 |
Re: resize GUI
Hi
Thanks, I have tried that one but unfortunately it only resizes sidewards, I mean what I need is to see the bottom part of the GUI. Do you know how to change this settings in a Linux environment? thanks CM |
February 3, 2005, 23:10 |
Re: resize GUI
pro-STAR pretty much requires a screen with a min resolution of 1280x1024. If you have less, you need to create a larger virtual screen and then scroll the screen up and down to see the entire GUI.
February 4, 2005, 05:00 |
Re: resize GUI
BTW, the minimal GUI size (working with a min resolution of 1280x1024) is hardwired. So you won't come around without steve's solution.
February 7, 2005, 04:28 |
Re: resize GUI
Actualy minimum acceptable resolution, when all GUI fits in the screen is 1152x864
how to resize the parameter file param.prp | ztdep | Siemens | 2 | October 27, 2005 08:31 |
