error message abot LES
Old   February 25, 2005, 06:54
Default error message abot LES
Ben
I study in pipe flow by the method of Les form.I set two inlets and one outlet ,and turbulence model set by Les/smagorinsky.I try to mant times set transient form in the time domain,but Starcd always shows mess error. "analysis must be transient and catnot use upwind for velocities to use an LES turbulence model" I already set qick for differencing schemes,but starcd still show the same error message.How to solve the question? thank~
Old   February 25, 2005, 08:23
Default Re: error message abot LES
yacine
you need to define the transient mode before you select the model. So: -unselect the model SMAGO turn of to laminar or something -select transient mode -select SMAGO model I wouldn't suggest that you use quick (too dissipative) use pure CD (value=1)
Error message-Floating point error Vaibhav FLUENT 3 December 7, 2007 05:38
UDF error message samy FLUENT 1 October 28, 2007 16:32
ERROR MESSAGE: line 1: parse error Lourival FLUENT 1 February 18, 2006 01:35
error message abot LES Ben Lu Siemens 1 March 6, 2005 22:14
Gambit 2.0 - Error Message (ACIS ERROR 1200) James FLUENT 1 May 14, 2003 08:13
