May 19, 2005, 04:44 |
Temperature profile in Solid cells
hello all,
My geometry consists of solid and fluid cells. The solid cells have two Boundary conditions. 1)The Boundary condition at the contact of fluid cells is Default Wall. 2)The other Boundary condition is Wall with constant Heat flux. The problem is, I could not see any Temperature behavior within the solid cells while postprocessing but can see the behavior in fluid cells. It would be really nice, if you could give me a suitable reply. Regards, Pramod. |
May 19, 2005, 08:07 |
Re: Temperature profile in Solid cells
The wall bc between solid and fluid must be Wall-conductive. How much solid cells do you have? Probably the gradient is very small and you only have to change the cscale?
May 20, 2005, 13:24 |
hi pramod,
i am also getting the same problem, i already made a query on this. but i got no answer. someday told the same way as the pete told. but that is not sufficient for us to forward. |
May 30, 2005, 13:56 |
Hi Manohar,
The behaviour in Solid cells can be seen. In the Post-processing, when you select the Temperature in the Scalar quantities rather than Total temperature in Calculated scalar quantities and keeping the Cell type activated.I hope it works for you. with regards, Pramod |
coupling solid and fluid cells?? | kcg | Siemens | 4 | March 13, 2007 09:39 |
Temperature profile across solid/interface/fire | Jie | FLUENT | 0 | August 1, 2006 23:29 |
Solid cells on symplane boundaries | samu | Siemens | 7 | May 29, 2006 10:07 |
Flow through solid cells | Julie Polyakh | Siemens | 1 | September 6, 2003 08:18 |
Building solid cells | kerem pekkan | Siemens | 0 | November 21, 2000 17:47 |
