star watch in v3.15
Old   May 12, 2005, 08:41
Default star watch in v3.15
cmv
Hi
I have been trying to use starwatch facility but I have not been able to run it. It is installed, I usually (as it says in the user guide) call it via 'starwatch' command and set it in the background. When I run my jobs and try to open a connection it can not see any running jobs. I am sure that the host adress is right and I am also positive about the lines you need to add to the etc/services file. Do you know what else could be wrong?
Many thanks
CM
Old   May 13, 2005, 05:25
Default Re: star watch in v3.15
Michele
Try to start Starwatch-Daemon before you start your job and then run Starwatch
Old   May 16, 2005, 01:01
sankar
steps to run starwatch.
1. start starwatch deamon before u start the analysis
2.start the analysis
3.once the calculation started after some iterations.disconnect the host and connect it again to the running process
4.starwatch will work
sankar
how to export a mesh from star design to star cd aounallah Siemens 4 March 6, 2009 06:22
Star watch not working rajesh Siemens 2 May 19, 2006 02:51
star-watch Dr C.Bhasker Siemens 4 June 20, 2005 21:33
