can't run moving mesh
Old   May 29, 2005, 05:18
Default can't run moving mesh
roger
when i run tut11-1 or tut13-1,i find the error message:PNP: ***ERROR*** No response from HOST "lxh" or invalid hostname. PNP: ==> Please check that you are specifying your nodes correctly. any one can tell me how to solve the problem,thanks!
Old   May 29, 2005, 12:31
Default Re: can't run moving mesh
Hubert Janocha
You are already using StarCD v3.20 - v3.24. This error message has nothing to do with the model setup anyway.
Check the hardware.ini in /usr/starcd/etc. It seems to be that there are some settings are not correct about the computers to use for this case, or that you possible have a network problem (means when "lxh" is your remote server for the calculation, and not you local workstation).
Moving Reference frame - UDF - Moving mesh modisa FLUENT 0 April 18, 2008 13:31
Moving Mesh & Not Rotating Mesh AB Siemens 1 October 25, 2004 03:10
moving mesh Jim Siemens 2 August 27, 2002 07:39
moving mesh zqf Siemens 1 June 19, 2002 01:30
moving mesh khb Main CFD Forum 1 June 5, 2002 10:46
