turbulence model for oil flow thr' small gap
Old   August 30, 2005, 04:46
Default turbulence model for oil flow thr' small gap
carno
Hi Experts,
I want to simulate a oil flow through a small gap of around 0.15mm. I just want to know following.
The gap section is rectangular.
1. Which turbulence model
2. How many cells in the gap
3. Target y+ value. (I think this will be decided by turbulence model). Let me know if anything else.
4. Finally is this possible to do in starcd 3.22? Anybody out there has done it?
Thanks a lot.
Old   August 30, 2005, 11:17
Default Re: turbulence model for oil flow thr' small gap
4xF
What is the typical Reynolds number of your flow? Because, if it is quite low, because oil has a high viscosity (depends in fact a lot on the temperature), the flow may not be turbulent at all...
Old   August 31, 2005, 08:12
carno
Actually this is a flow through a clutch plate gap. So the temperatures will be around 100 dec C. I do not know yet the flow rate.
YOu are right. It may not be a turbulent case. I will let you know the Re number.
Thanks.
Eul-Eul flow, k-e-kp-ep-Theta Turbulence model us FLUENT 5 April 5, 2011 02:29
Turbulence model for Laminar flow Terry Main CFD Forum 8 August 14, 2010 05:45
Rotational flow turbulence model ntrask OpenFOAM Running, Solving & CFD 3 February 3, 2009 10:59
validating turbulence model on flow around a car Pedro CFX 1 February 20, 2008 16:32
Turbulence model for transsonic flow Wei Main CFD Forum 1 April 14, 2005 04:46
