August 3, 2005, 15:54 |
Pressure average on boundary
a need to calculate the pressure average of the inlet. the way i want to do it is multiplying the P*a/A. where P and a are local at each cell and A is the total area.
the way i'm doing it is I load the Pressure to a register and when i want to load the Area of the inlet shells to another register, it loads them in separate cells. i'm trying to figure way to attach the shells to the boundary, but i haven't found a way, can anybody help? thanks |
August 5, 2005, 19:55 |
Re: Pressure average on boundary
if convergence check is switched on you find the boundary pressures in the info file. So you don't have to calculate something. If you want any scalar (be carefull with vector data) in any location of the mesh you can create a monitoring cell set. The results are witen in the *.ecd file. You can load this file in a graph or view it with an editor to see the value of the set. The same for monitoring boundary data. The results are in *.erd.
Of course, shells and 3D cells are cells on there own with there own id number, which must be different. You can map the 3D cell results to the shells with pmap. Then you have the the pressure and the according area of the wanted cell-id. with cfind you can generate shells onto 3D fluid cells. See http://www.adapco-online.com/adapco_...sh1/index.html Additionally you can create arbitrary planes (shells) (a cut through 3d cells) with pscreate. |
Average pressure on a face. | Mario Tremblay | CFX | 2 | February 19, 2009 13:08 |
how to plot the average pressure over each period? | Tsui | Phoenics | 1 | June 5, 2008 09:16 |
calculation average pressure in a plane with UDF | Vitalij | FLUENT | 1 | April 10, 2007 03:39 |
Area average of pressure on a section | Radhika | Siemens | 4 | April 4, 2007 18:05 |
how to calculate the average pressure | lenson | Siemens | 0 | March 4, 2005 03:24 |
