coupling
Old   August 23, 2005, 00:33
Default coupling
novice
Hi All,
I just want to know disadvantages of couplings in STARCD. Since my geometry is very complex and I want to use different meshes and couplings. Whats happens if there are too many couplings? Solution time, memory etc etc.
Thanks a lot
Old   August 31, 2005, 02:12
Default Re: coupling
Hubert Janocha
Integral couples should never affect your results, solution time and memory.
Arbitrary couples are OK too, but can be a problem in very high compressible flows (about mach 0.8). The situation becomes worse when partial boundaries are used in such flows.
But for normal cases the implementing of couples in starcd is very god.
Hint: If possible for your complex geometrie, use block structured meshing (escecially for areas to be replaced), and not ProAM.
one/two way coupling of DPM Angela FLUENT 3 April 28, 2008 09:29
Coupling 1D and CFD James Siemens 1 February 6, 2007 07:44
Two way coupling in DPM fpingqian FLUENT 3 November 28, 2004 22:47
coupling uds Andrew Garrard FLUENT 0 December 1, 2003 06:38
FEM and CFD coupling DEMERSSEMAN Rémi Main CFD Forum 9 April 15, 1999 02:37
