*** ERROR #320 *** INCORRECT WALL HEAT BOUNDARY... |
September 9, 2005, 07:19 |
Dear All,
My model has two fluids and one solid. I made all interfaces between the fliuds and solid as conducting wall.There is no interface between the two fluids. when i checked the model it gives no error but when i give the run, it gives the following error. *** ERROR #320 *** INCORRECT WALL HEAT BOUNDARY SPEC AT PHYSICAL BOUNDARY Anybody has idea about what is causing this error? Please help me. BV |
September 11, 2005, 17:26 |
Re: *** ERROR #320 *** INCORRECT WALL HEAT BOUNDAR
did you switch on conjugate heat transfer?
September 12, 2005, 03:09 |
Yes, I have swithched on the Conjugate Heat Transfer.
Any other reason which is causing this problem?? BV |
Error Orient Face incorrect | MK | Siemens | 5 | January 19, 2009 08:46 |
Incorrect wall function BC info in User Guide | schoon | OpenFOAM Bugs | 0 | October 23, 2008 10:35 |
Wall boundary condition (heat transfer) | Arnold | FLUENT | 4 | February 16, 2006 22:35 |
Heat Transfer & Boundary Conditions across 2D wall | SAAD | Main CFD Forum | 6 | March 13, 2005 12:42 |
wall heat boundary | Marco | Siemens | 5 | September 9, 2004 09:50 |
