Particle Tracks
Old   October 7, 2005, 06:55
Default Particle Tracks
Anand
I have solved a steady state flow simulation. I would like to plot particle tracks with 1. walls of fluid as transperrent with only one color display and 2. color of particle track should represent instantaneous velocity magnitude.
Also, if I choose ribbon option for plotting, I observed that particle tracks have infinite length irrespective of end time in GL mode. Can I adjust particle tracks length by controlling end time?
If anyone knows in details pl let me know
Thanks in advance Regards Anand
Old   October 10, 2005, 06:33
Default Re: Particle Tracks
carno
Since you have solved steady state, your second statement is not going to work. You can not stop particles in between. They will go out from the out BC or end at walls.
Old   October 10, 2005, 13:38
Anand
Thanks for your reply.
But I observed that I could control length of particle tracks by controlling end time when I use streamline option instead of ribbon in GL mode
Anyway, thanks again Regards Anand
Can't see Particle Tracks! Lior FLUENT 5 July 10, 2011 03:43
particle-tracks torsten Siemens 0 January 30, 2007 08:58
particle tracks novice Siemens 0 February 3, 2005 02:15
Particle Tracks Pravir FLUENT 0 February 2, 2003 23:01
Particle Tracks Ram FLUENT 2 January 25, 2003 11:08
