HOW TO "UNDO " IN STAR -CD
Old   October 20, 2005, 04:38
Default HOW TO "UNDO " IN STAR -CD
ztdep
I WANT TO PERFORM THE UNDO IN STAR-CD ,PLEASE HELP ME
REGARDS
Old   October 20, 2005, 08:29
Default Re: HOW TO "UNDO " IN STAR -CD
Jamie
There is no "undo" in STAR-CD. There is "vundo" for vertex operations. If you are going to make a change to the model that you might not do correctly the first time, it's best to save the model first. Then if the result isn't what you were expecting, you can resume from the last save (File --> Resume). You can also use the "recover" command, which executes previous commands from the .echo file. Check the help on "reco." (On the command line: help reco)
how to export a mesh from star design to star cd aounallah Siemens 4 March 6, 2009 06:22
problem to find undo mojtaba Siemens 4 January 24, 2008 19:44
Star Design to Star-CD(Prostar) AB Siemens 5 October 28, 2004 12:21
