How to caculate the frontal area of a car?
Old   November 2, 2005, 10:27
Default How to caculate the frontal area of a car?
Kevin
Can starcd do it?
Old   November 4, 2005, 17:00
Default Re: How to caculate the frontal area of a car?
William Blake
You might use the integrate command. Just define a section using the spoi and snorm commands and run the integrate command after that.
Old   November 9, 2005, 07:16
Tobbe
The integrate command will probably not produce the correct answer, since a typical carbody dont have a specific point where the projected area equals the section-area. i.e. if you use the integrate command where the mirrors are you will miss the roof-line. In esaero there is an inbuilt function to get the projected area, but I suppose you dont have acces to esaero. However, what esaero basically does, is to project all the vertices of the car, in the x-direction (vproj command), onto a cset of shells (i.e. the inlet). Then get a subset of the cset consisting of the cells being "hit" by a vertice. Then you can get the area of the resulting cset. I dont know exactly how to get the subset automatically, but if you are only doing it once, you can probably cut out the subset manually (cset dele zone & cset subs zone).
Old   November 11, 2005, 23:12
Kevin
Yes,just as what you said, the integrate command cannot realize what i want,after I tried.Thanks for your method of esaero,it seem to be a good way to caculate the frotal area.Others ,I could achieved it in another software--Ansys ICEM.
Frontal projected reference face area computation from patch kprzysowagmailcom OpenFOAM Pre-Processing 0 January 6, 2009 10:06
Drag coefficient - frontal area JSM FLUENT 3 December 3, 2007 05:57
how to caculate area,force and moment in Fluent mimibenben FLUENT 0 July 3, 2006 22:00
Frontal area calculation Stefan CFX 1 June 12, 2006 21:03
frontal projected area sam FLUENT 0 August 2, 2003 02:45
