how to draw velocity profile(in unstructure pipe )
Old   October 17, 2005, 06:56
Default how to draw velocity profile(in unstructure pipe )
lenson
recently I deal with a model using "gambit" software to import in the star cd. The model is a unstructure pipe . I want to get the calculated velocity profile in the outlet of the pipe . Because of unstructure grids,I can not get the vertex set to draw the velocity profile. can anyone help me? thx~
Old   October 17, 2005, 12:50
Default Re: how to draw velocity profile(in unstructure pi
steve
There are several ways of putting in "sensor" points anywhere you want. They don't have to correspond to pre-existing vertices.
Old   October 18, 2005, 08:52
ztdep
how to put in "senso" points
regards
Old   October 18, 2005, 16:38
Tom
You can define a vertex at the centroid of other verices using the command VVERTEX or cells using the VCELL command. Then use SENSOR,ADD to put the sensors there. Use the help command, of course to get the details of these commands.
Tom
Old   October 19, 2005, 09:57
ztdep
where can i get the every command in star-cd ,
regards
Old   October 19, 2005, 16:42
staruser
Look at help in proSTAR. There is a section called "Commands" (I think). This should contain all commands available in proSTAR. An easier way is to use "help" on the command line or F1. In the help window you can enter a key word ("sensor" in this case); with "Enter" you can browse through all commands where the key word is mentioned in the description.
Regards
Old   October 25, 2005, 13:00
tomosada
In the version of 3.2x.
The new gui of grapher is very easy to use.
1. You can choose two vertexs to make a line and setting the number of extract data points (a little like tecplot).
2. load the varable you want.
3. creat the draw.
Old   October 26, 2005, 05:21
lenson
To tomosada: if the model built in star cd version 3.15 runs to convergent condition , can I open the model in version 3.2x ?
Old   November 19, 2005, 06:13
haji
Laminar, Transition and Turbulent Region Flows â€" Images and
How to draw the velocity of phases separately kb FLUENT 0 August 25, 2007 07:25
How to draw transversal velocity profile Kb FLUENT 3 August 24, 2007 20:54
How to draw pipe mesh Ismael FLUENT 2 March 3, 2007 16:27
Buy software for draw vector velocity Yassin FLUENT 0 January 18, 2006 11:35
Draw velocity profiles in tecplot scubme FLUENT 1 December 3, 2004 08:48
