November 21, 2005, 07:35 |
Howto manually merge a pst-file?
Hello dear starcd-colleagues!
As the subject states, how do I manually merge a pst-file from a parallel run? The automatic merge of the pstt and pst-files failed due to the pstt-file being to large (2 GB on each node... my bad...) In version 3150A there existed a command to do this but I can't seem to find a similair command in v3240, which is what I'm using. Hope anyone of you can help me. Kind regards DrA |
November 21, 2005, 08:15 |
Re: Howto manually merge a pst-file?
The following command: $STAR/bin/mergepst will do the trick (make sure that you have sourced your STAR intallation before).
December 6, 2005, 08:57 |
Yes, that's right. In the new starcd version v3.2x mergepst and mergepstt are no longer in the environment path, but still there (start a search: find /usr/starcd -name "mergepst*")
mergepstt will fail again when you ty it manually, because of the 2GB limitation on 32bit machines. I do it this way: - use the "Backup Frequency" in NavCenter for every wanted timestep intervall (e.g. every 5 timesteps). Star writes out a <case>.pst_xxxx (xxxx=timestep) file in each cpu-domain. - use the mergepst binary to merge this domain-<case>.pst_xxxx-file together timestep for timestep. (Be sure to use the new mergepst, and NOT that one of v3150A !!!) Possibly you become a little mad for this job. You can write a small c-shell script, containing a loop (over all wanted timesteps) doing that for you (use "if" and "goto" commands). With this method you can run millions of cells and many many thousends timestep without getting a problem with 2GB. |
Calculation of Drag Coefficient manually | PRASHANT GHADGE | FLUENT | 4 | December 13, 2012 15:31 |
HOWTO use fieldAverage | alesch | OpenFOAM Running, Solving & CFD | 6 | October 22, 2012 01:51 |
MotionUBoundaryPatch assignment HowTo | bfa | OpenFOAM Running, Solving & CFD | 22 | November 24, 2011 11:52 |
Accessing the SVN Repository Howto | philippose | OpenFOAM Installation | 3 | August 31, 2007 15:39 |
temperature gradient howto | tomasz bednarz | FLUENT | 0 | April 27, 2006 00:35 |
