Piezo Pressure
Old   January 1, 2006, 23:41
Default Piezo Pressure
CFDian
This seems to be a simple question. However can anyone tell me the significance of piezo swith in pressure boundary condition. More specifically what difference shall I expect in the results when I swith on piezo and static pressure respectively
Regards CFDian
Old   January 2, 2006, 02:30
Default Re: Piezo Pressure
carno
piezo is active only when you have switched on gravity.
Old   January 3, 2006, 00:31
CFDian
Thank you for the reply. But I would like to know how does gravity relate to Piezo pressure.
Old   January 3, 2006, 07:08
carno
All details are given in starcd manual.
When gravity is on the datum head will get added in the pressure. (pressure exerted by vertical fluid column above the point)
What type of pressure can give the pressure drop david FLUENT 1 February 17, 2014 11:51
Pressure driven laminar flow simpleFoam pressure higher at the outlet than inlet gabriel OpenFOAM Running, Solving & CFD 16 September 30, 2009 18:20
Forcing pressure outlet according to pressure prob Cedric FLUENT 0 July 29, 2005 11:49
pressure driven flow by pressure correction method justentered Main CFD Forum 0 December 29, 2003 23:52
Total pressure to static pressure ratio roadracer Siemens 1 April 17, 2003 05:31
