surf wrap - baffle thickness
Old   April 20, 2006, 09:59
Default surf wrap - baffle thickness
azmir
I wish the baffle thickness during surface wrap can remain zero when it is not activated. I've tried using the default value of 2, 10, 0 and even deactivated it. Turned out the wrapped surface always came out to have same thickness of 2mm! Is this my only isolated case or have others experienced the same? If so, is there going to be a remedy in the near future?
Wrap Angle for Impeller shraman Main CFD Forum 1 April 5, 2019 13:27
specifying wrap angle in BladeGen avk CFX 1 April 5, 2019 13:19
Pro surf Konstantinos Siemens 11 May 10, 2006 08:32
Simple query on Pro Surf Venkatesh.V Siemens 0 April 22, 2006 02:32
Catia V5 and Pro-Surf Rainer Siemens 4 June 18, 2004 03:58
