How to model intersecting pipes
Old   June 7, 2006, 08:50
Default How to model intersecting pipes
Ankush Aggarwal
Hi, I am modelling two intersecting pipes(normal to each other) in Star CD. But, the problem is how to get the curve of intersection of the two pipes...pleace respond as early as possible. Thanks in advance Ankush Aggarwal
Old   June 8, 2006, 08:35
Default Re: How to model intersecting pipes
Anton Lyaskin
Try VINTERSECT command. You need one pipe to be represented by fluid cells and the other by surface shells for it
Old   June 8, 2006, 09:33
Ankush Aggarwal
I have made the interface using vproject and completed the meshing but there are some overlaping cells at the intersection of the pipes(even though I projected the vertices on the surface)....and I don't know how to correct that....if you can help please. Thanks
intersecting cylinders m malik Main CFD Forum 2 November 2, 2011 08:25
model of pipes inside pipe carmen FLUENT 0 January 22, 2009 09:27
Intersecting sliding interface jaswi OpenFOAM Running, Solving & CFD 0 February 15, 2008 00:07
self intersecting (mesh volume) Eko CFX 0 May 30, 2007 18:55
Self intersecting Carlos Saraiva Siemens 0 January 23, 2003 08:33
