from STAR-Design to STAR-CCM+
Old   June 20, 2006, 17:58
Default from STAR-Design to STAR-CCM+
Martin Hauser
I am trying to set up the model and the mesh in STAR-Design and then to import it in STAR-CCM+, using the .ngeom file format. As I want to model heat transfer between a solid and a fluid, I assigned the appropriate domains in STAR-Design. But when importing the mesh in STAR-CCM+ it only recognizes one fluid region. Therefore my questions are - How must two domains, solid and fluid, in STAR-Design created to be recognized by STAR-CCM+ to be two different regions? Or must the fluid region in STAR-CCM+ be splitted after the importing?
Many thanks!
Old   June 22, 2006, 12:36
Default Re: from STAR-Design to STAR-CCM+
Jamie
After you've set up the model, in the menu bar click on:
Solver --> Solver Preprocessing
This will create a .sim file for STAR-CCM+. Save your STAR-Design model and then the .sim file will be moved to a subdirectory (same name as your STAR-Design model name). It will be called solverun.sim. Open that in STAR-CCM+ and everything should be all set.
how to export a mesh from star design to star cd aounallah Siemens 4 March 6, 2009 06:22
star-cd and design GG Siemens 4 March 2, 2008 09:31
Star-Design beginner Siemens 1 October 6, 2005 06:39
Star Design to Star-CD(Prostar) AB Siemens 5 October 28, 2004 12:21
