segmentation fault
Old   June 29, 2006, 02:20
Default segmentation fault
tipakorn
I used Pro star amm. when I do it follow TUT until step 3 (generated subsurface), Prostar would close itself and show error " segmentation fault". What's this error? How to correct it?
Old   June 29, 2006, 22:03
Default Re: segmentation fault
Shariff
I gues you are using the mesh wizard window for the tut. Try running the step 3 on the automesh window rather than using the mesh wizard. I hope this helps. Shariff
Old   July 2, 2006, 08:49
laure
I have to deal with this segmentation fault every now and then. Every time a model is not very basic, then displaying cells, graphs or anything else leads to a segmentation fault. Is there a way to be sure that the memory we attibute to each variable is high enough to avoid this error. Is there a patch somewhere to face this bug? Regards, Laure
Old   July 5, 2006, 04:37
lizhihua
This error occurs when I am using the windows version, and all I can do is to save the model very often.
Old   July 5, 2006, 10:37
airfoil
If you are using windows version v3.26 then there is a segmentation fault bug. You can update to v2.26.006. There is no problem is v3.24.
Old   July 11, 2006, 01:05
christophe
i have the same problem, every minute "save model"! quite annoying... i'll try to update
Old   July 31, 2006, 07:56
css
Segmentation fault occurs due to memory problem (may be insufficient RAM.You can try the following 1.upgrade the RAM. (As per your problem size) 2.Resize your param.prp file. 3.last option is delete the param.prp file and open your model. (while open the model param.prp file will be automatically created. 4.Insted of using 3.26 you can use 3.24 or 3.22 which are very stable.
hope it helps.
[Technical] Segmentation fault in map msg30 OpenFOAM Meshing & Mesh Conversion 6 March 27, 2008 10:49
Segmentation fault billy OpenFOAM Installation 20 April 23, 2007 22:57
segmentation fault natesan Siemens 4 January 12, 2004 08:51
Segmentation fault Veebs Siemens 3 June 4, 2002 22:17
Segmentation fault Jose Sanchez Siemens 1 December 16, 2001 08:13
