turbulence modeling error at a stagnation point
Old   August 8, 2006, 04:28
Default turbulence modeling error at a stagnation point
erdem
hi
I'm studying external aerodynamics of Ahmed Body car geometry. I have used realizable k-eps, SST k-omega and RSM models. in terms of drag coefficient I got similar values with all models. but all of them calculated nearly 1.5-2 times drag at the front of the body (comparing with the original experiments. Realizable k-epsilon has the highest drag on the front.
why does this happen? would you please help me about investigating the greater pressures at the front caused by turbulence modeling? I have to write a discussion about it. this is really important. thanks for you time.
Erdem
Old   August 8, 2006, 11:33
Default Re: turbulence modeling error at a stagnation poin
Pauli
If I answered your question & you used my answer, you might get penalized for cheating. So I will do you a favor & refrain from answering. So Google on....
Old   August 8, 2006, 11:40
erdem
why cheating? you or google? whats makes the difference?
Old   August 8, 2006, 13:09
Pauli
You sound like a student looking for an easy answer. If you use google at least you are doing the research.
Old   August 9, 2006, 10:44
HomeworkIsMe
Durbin, P. A. (1996), "On the k-epsilon Stagnation Point Anomaly"", International Journal of Heat and Fluid Flow, 1996, Vol. 17, pp. 89-90.
turbulence modeling error at a stagnation point erdem Fidelity CFD 2 August 15, 2006 15:40
turbulence modeling error at a stagnation point erdem CFX 3 August 9, 2006 19:54
turbulence modeling error at a stagnation point erdem Main CFD Forum 2 August 8, 2006 10:28
turbulence modeling error at a stagnation point erdem FLUENT 0 August 8, 2006 04:25
How can I get Cp=1 at the stagnation point ? largeeedysimulation FLUENT 1 September 7, 2005 18:03
