turbulence modeling error at a stagnation point |
August 8, 2006, 04:28 |
hi
I'm studying external aerodynamics of Ahmed Body car geometry. I have used realizable k-eps, SST k-omega and RSM models. in terms of drag coefficient I got similar values with all models. but all of them calculated nearly 1.5-2 times drag at the front of the body (comparing with the original experiments. Realizable k-epsilon has the highest drag on the front. why does this happen? would you please help me about investigating the greater pressures at the front caused by turbulence modeling? I have to write a discussion about it. this is really important. thanks for you time. Erdem |
August 8, 2006, 11:33 |
Re: turbulence modeling error at a stagnation poin
If I answered your question & you used my answer, you might get penalized for cheating. So I will do you a favor & refrain from answering. So Google on....
August 8, 2006, 11:40 |
why cheating? you or google? whats makes the difference?
August 8, 2006, 13:09 |
You sound like a student looking for an easy answer. If you use google at least you are doing the research.
August 9, 2006, 10:44 |
Durbin, P. A. (1996), "On the k-epsilon Stagnation Point Anomaly"", International Journal of Heat and Fluid Flow, 1996, Vol. 17, pp. 89-90.
turbulence modeling error at a stagnation point | erdem | Fidelity CFD | 2 | August 15, 2006 15:40 |
turbulence modeling error at a stagnation point | erdem | CFX | 3 | August 9, 2006 19:54 |
turbulence modeling error at a stagnation point | erdem | Main CFD Forum | 2 | August 8, 2006 10:28 |
turbulence modeling error at a stagnation point | erdem | FLUENT | 0 | August 8, 2006 04:25 |
How can I get Cp=1 at the stagnation point ? | largeeedysimulation | FLUENT | 1 | September 7, 2005 18:03 |
