September 25, 2006, 02:13 |
can not run starcd 3.15 in windows XP?
I have restalled my windows system,and starcd also been restalled,but when I begin to use it,there is some errors as bellow: Licensing problem:unable to list licensed features cannot connect to license server The server (lmgrd)has not been started yet,or the wrong port@host or license file hss been changed. Server name: localhost license path:......(directory which I install starcd in)
Flexlm error: -15,10. System Error:10061 "WinSock:Connection refused" For turther ...... what's the problem? and how can I solve it? wish your quickly reply!! THank you very much!! |
September 25, 2006, 06:53 |
Re: can not run starcd 3.15 in windows XP?
What's you licensing type - nodelocked or via FlexLM local server? Check LM_LICENSE_FILE system variable and make sure that FlexLM service is running for licensing via server. Try using lmtools.
November 3, 2006, 11:46 |
Anton can you expand your explain please because I have the exactly same problem ..
Help! Can I install Es-Ice with Starcd in Windows? | Deisler | Siemens | 5 | April 24, 2007 08:01 |
New to StarCD | Matt | Siemens | 2 | September 23, 2005 22:50 |
New StarCD version3.22 | Samir | Siemens | 15 | November 23, 2004 19:45 |
Convert from StarCD 3.10 to StarCD 3.15 | Jing | Siemens | 1 | April 17, 2002 09:22 |
Meshing in StarCD | anindya | Siemens | 1 | December 10, 2001 03:25 |
