Structure or unstructured mesh
Old   October 22, 2006, 11:22
Default Structure or unstructured mesh
Nikos
Guys,
when trying to simulate the flow around a blade of a water turbine, what do you thing would be more suitable, a structured or an unstructured mesh and why?
Thanks! Nikos
Old   October 22, 2006, 18:29
Default Re: Structure or unstructured mesh
TG
You need well shaped cells that have faces that are parallel and perpendicular to the blade suface. They need to follow the blade contours. Whether you do that with a structured or unstructured mesh is completely irrelevant.
Old   November 9, 2006, 18:35
Yudha
What i did for a foil was creating a boundary layer that is perpendicular to the foil surface (about 20 layers; up to you)(ie. the boundary followed the shape of foil , they call it C grid) then outside the boundary layer, i made unstructured tringular mesh.then the further outside i used rectangular structured mesh. thats what my lecturer taught me.
unstructured or structure mesh? fadhil FLUENT 5 July 14, 2008 03:12
edge/face based data structure unstructured grid sundeep Main CFD Forum 0 April 25, 2007 12:36
Structure vs unstructured meshes Des Aubery Main CFD Forum 2 July 25, 2003 23:11
unstructured mesh data structure for FVM J. Kim Main CFD Forum 3 February 17, 2002 02:43
Data Structure for the unstructured finite volume method Anthony Main CFD Forum 4 February 2, 1999 19:24
