trimmer mesh vs Polyhedral mesh
Old   April 30, 2009, 16:56
Default trimmer mesh vs Polyhedral mesh
Marcelo
Marcelo is on a distinguished road
Dear All,
I need to mesh a complicate shape, with the trimmer mesher is easier but I dont know if this method have some disadvantage in front Polyhedral StarCCM+ mesh...
Marcelo is offline   Reply With Quote
Old   May 1, 2009, 11:31
Aroon
vishyaroon is on a distinguished road
Both trimmer and polyhedral should work well. I had carried out a comparitive study for heat exchangers and showed no difference.
You mention that your's is a complex case. Can you tell me what case it is? If the geometry is complicated both these schemes can handle it. If you have additional physics like CHT or something, one may be better than the other. for eg. polyhedral is supposed to be better in CHT as you can use the same mesh continua for both solid and fluid.
vishyaroon is offline   Reply With Quote
Old   February 4, 2015, 09:00
Default Aircraft's winglets analysis
Chris
chris1232 is on a distinguished road
Im confusing which mesh should be bettwer for aircraft's winglets analysis. I will be changing the length and the cant angle of a winglet and see how its affects the CL, CD etc.
Should I go for Trimmer mesh as it is probably faster and good or should I go for Polyhedral mesh?
It will be part of a wing tested which will be 6m long. Tested uder 20m/s 60m/s and 100m/s at constant AOA
Any idea of what settings should I apply for the mesh?
Thanks.
chris1232 is offline   Reply With Quote
[Technical] Polyhedral mesh generation lr103476 OpenFOAM Meshing & Mesh Conversion 49 July 17, 2012 02:59
Dynamic moving mesh Pei-Ying Hsieh (Hsieh) OpenFOAM Running, Solving & CFD 64 June 7, 2012 10:04
ICEM 10 mesh question DAK565656 CFX 6 May 8, 2007 12:16
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
Fluent 6.3.16 + Polyehdral Meshes Carlos FLUENT 3 March 15, 2007 03:09
