problem with compiler and LIVCLL
Old   December 10, 2006, 11:33
Default problem with compiler and LIVCLL
RX
Hi guys,
I am using star-cd version 3.26 to solve moving mesh problem. But no matter for the case provided by star-cd company, or for my personal case, when I wanna run the job, the computor always told me a warning about LIVCLL and a error about Fortran compiler "pgf90". Anyone know what is wrong with this problem? For the compiler, where can I get it?
To better locate my problem, I post the prompt lines for tutorial 11, for which I used the case provided by star-cd.
bash-3.00$ star PNP: Initialized [2006-12-10-16:33:12] Automatic Sequential Automatic Parallel analyzer.
PNP: Allocated "mace-r-ruixu,1" resource (1 process).
PNP: Overload STAR master processor with external moving mesh code.
PNP: Assigned "mace-r-ruixu,1" to STAR solver (1 process).
PNP: Assigned "mace-r-ruixu,1" to external moving mesh code (1 process).
PNP: **WARNING** External moving mesh code look a head cannot be used with LIVCLL user coding.
PNP: Analyzing User coding in "ufile" directory.
PNP: **WARNING** Cannot find required Fortran compiler "pgf90".
PNP: ==> Please check that you have installed the Fortran compiler correctly.
PNP: ***ERROR*** Compilation error in user file "ufile/uparm.f".
PNP: ==> Please check the compilation error messages.
Any response will be highly appreciated.
Many thanks in advance!
Old   December 10, 2006, 14:53
Default Re: problem with compiler and LIVCLL
Ben
You need pgf to use any of the user coding, you can buy it from http://www.pgroup.com/
ABSOFT COMPILER PROBLEM? LIN Siemens 0 October 14, 2008 13:40
Fortran compiler problem Luke Siemens 2 September 18, 2008 03:43
compiler problem Jay Siemens 2 January 9, 2008 18:40
Fortran compiler problem jeff Main CFD Forum 6 July 1, 2005 13:12
The Incredible Segfaulting LIVCLL cjtune Siemens 6 March 4, 2003 00:07
