Vehicle CAD Model Meshing
Old   June 4, 2007, 16:26
Default Vehicle CAD Model Meshing
B Bru
I am about to attempt to mesh a car that was designed in Solidworks. I plan on exporting the vehicle CAD files as .stl.
My questions:
1) There are many parts that are under the body of the car and do not need to be included in the analysis. Should I just suppress these, or when I when I use pro-surf can I just select the surfaces I want to be included in the surface mesh?
2) The body is made of panels that DO NOT form a continous surface. They have design clearances in them so they fit together easy. The clearance is about 1mm between the panels. How is pro-surf going to handle this? Can they be stitched together for the analysis? It seems like this kind of discontinuity probably will cause issues unless there is a built in way to deal with them up front.
Thanks in advance to anybody who replys!
Old   June 4, 2007, 17:06
Default Re: Vehicle CAD Model Meshing
Ben
use the surface wrapper not pro-surf
Old   June 4, 2007, 17:44
B Bru
Thanks Ben, I've never heard of that utility. Is that something I would find within Pro-Star?
Old   June 6, 2007, 00:39
Airfoil
It is in the Proam. It is located at Proam -> Prepare Surfaces -> Create New Surfaces -> Surface Wrapper
Old   June 7, 2007, 12:47
B Bru
Thanks Airfoild. This will make my life a lot easier
Old   June 8, 2007, 17:30
Nari
Use STAR-CCM+ wrapper option.. it is very easy than proam wrapper..
if you use STAR-CD V.4 you can transfer your volume mesh from STAR-CCM+ to STAR-CD v.4... as *.ccm file..
Else if you use STAR-CD v.3.2x you can transfer your surface mesh..
Trimmer meshing model STAR-CCM+ rH Siemens 3 December 17, 2008 16:16
Meshing difficulty in Gambit on a complex model Peter FLUENT 1 July 16, 2008 15:59
Dynamic meshing-In-cylinder model Mary FLUENT 2 May 28, 2008 08:15
Turbulence Model and Meshing Advice Jason FLUENT 1 January 31, 2006 13:05
Meshing Techniques & k-omega turbulence model Nurul Murad FLUENT 1 April 2, 2004 12:19
