weller+problem
Old   March 12, 2007, 04:34
Default weller+problem
Kuriakose
I am simulating GDI spray combustion using weller 3 equation model. My fuel injection starts at 90 degree after TDC. I set the combustion model and got the following scalars: C8H18, O2,CO2,H2O,N2,RVB,WRINKLE,MIXTURE FRACTION and N0. When I switched on the chemical scheme prostar automatically set the values of RVB=1 and WRINKLE=1. Hence I initialised the other scalars o2 as 0.233 and N2 as 0.767 (No EGR). Boundary also I initialisesd with the same concentration of O2 and N2. The problem I am facing is once the fuel injection starts The engine output file(*.spd01) shows some values of burned scalar C8H18( which should occur near TDC) . It also shows some values of CO2 and H2O. This happens immediately after the start of fuel injection (90 degree after TDC). The evaporated scalar 1 (i.e C8H18) also show some unrealistic value of the order od 0.92314E+34).
The above mentioned phenomena doesnot occur when I switched off the chemical scheme( which ofcourse has no meaning for combustion simulation)
Please help me in this regard. Thanks in Advance
Bye Kuri
Where to find the theory for weller flamet combustion model 21kalee OpenFOAM Running, Solving & CFD 7 December 19, 2012 17:18
Combustion in ICE - Weller model roadracer Siemens 1 July 22, 2009 04:54
Weller 3 Equation Kuriokose Siemens 0 March 1, 2007 01:52
Weller combustion model roadracer Siemens 0 October 6, 2003 05:07
combuston in ICE Weller model II roadracer Siemens 0 September 3, 2003 12:28
