stupid question-how to measure the model ?
Old   June 19, 2007, 05:07
Default stupid question-how to measure the model ?
mic
i mean, i export an iges file, then i resurface it through pro surf, then i open it in pro-am, but how can i know if it's always in mm, or it has turned to meters ? i took a look in the utility panel, but nothing...
Old   June 19, 2007, 05:53
Default Re: stupid question-how to measure the model ?
Balduin Bankerotti
vdis vx vx
and pick 2 vertices.
Old   June 19, 2007, 07:33
James
Use the range command
cset news fluid
range cell cset
similarly for vertices,etc.
Old   June 20, 2007, 07:50
mic
ok, both the procedures are right, i retrieve the extent of cell set, but what i meant what "i do set meters or millimeters before running the simulation under 'run analysis interactively' or i have to trust star-cd ?" thank you again
Old   June 20, 2007, 08:02
James
Once you know the units you pick the right one, you should see the scale factor used in the geom command that will show up in the output window/ in the history.
Star always wants its geometry in meters. The second parameter after geom in the geom command is the scale factor between model units and meters.
A stupid question luckyluke OpenFOAM Running, Solving & CFD 14 August 13, 2007 04:25
Perhaps a stupid question... HSeldon FLUENT 0 March 9, 2007 12:14
Stupid question Dr. Nick Main CFD Forum 0 August 5, 2006 16:31
stupid question Andrew Hayes Main CFD Forum 9 December 20, 2005 11:25
A (very, very) stupid FEM Question Carlos Main CFD Forum 2 September 21, 2002 09:31
