Banal question concerning use of registers
Old   July 15, 2007, 19:21
Default Banal question concerning use of registers
Flavio
Hi all. I made some simulations over a wing profile. I'd like to create the classical graph showing the Cp (pressure coefficient) on the y-axis and the cord percentage x/c on the x-axis. (check this link to get what i'm trying to tell you using my awful english:http://www.cfd.tu-berlin.de/research...port/img13.png) I esaily got out a register with the values of pressure in the cells lying on the profile, but my matter is: how can i get a register with the x-coordinates of the profile?
Thanks a lot everyone would like to help. Bye.
Old   July 17, 2007, 03:44
Default Re: Banal question concerning use of registers
james
You can use
OPERATE GETC X 4
to get the data into a post register (you can do this in any co-ordinate system).
and then use the same method you used for the pressure.
In general the star graphing is somewhat painful. It is generally easier to use
*get and gparam
in a prostar loop (*define,*end,*loop)
to create columns of data, then use sdata to make a text file which you can then read into something like excel.
Old   July 17, 2007, 07:03
Flavio
Thanks a lot. I just wish you had post before i withdraw the relation about the simulations XD
Thanks anyway, bye.
how to get cell face area and U in registers chinayu Siemens 3 May 16, 2006 08:47
A question Noname Main CFD Forum 1 April 27, 2006 19:03
UDF question Pratap FLUENT 6 February 10, 2005 09:45
Problems saving graph registers data Julie Polyakh Siemens 4 August 6, 2003 13:32
Post-process: how to extract Graph Registers' data Jiaying Xu Siemens 11 July 17, 2002 04:38
