Segmentation fault.
Old   November 5, 2007, 17:32
Default Segmentation fault.
Nari
Hi everybody..
I have installed STAR-CD and STAR-CCM+ in Linux (all are 32 bit versions). But after writing "prostar" or "proam" or "starccm+" in konsole or terminal i got segmentation fault error. And nothing is running..
I know this is may be frequently asked question.. and all are may be because of my hardware configuration.. but i must fix it immidiately..
Have anyone any suggestion for fixing it?
Thanks already..
Old   November 8, 2007, 04:41
Default Re: Segmentation fault.
BastiL
What is the exact error message? Did you set environment properly?
Old   November 8, 2007, 04:47
Nariman Mehdiyev
only there is written "segmentation fault"..
i did all sayed in installation guide..
what else can i do? if you have any suggestion please write..
Old   November 8, 2007, 05:04
usker
Search this site. You will find much information about it. This error depends on the case. There isn't the only answer to fix it. It can be many things. Just search this forum, hope you will find something.
Regards
[Technical] Segmentation fault in map msg30 OpenFOAM Meshing & Mesh Conversion 6 March 27, 2008 10:49
Segmentation fault billy OpenFOAM Installation 20 April 23, 2007 22:57
segmentation fault natesan Siemens 4 January 12, 2004 08:51
Segmentation fault Veebs Siemens 3 June 4, 2002 22:17
Segmentation fault Jose Sanchez Siemens 1 December 16, 2001 08:13
