Fortran compiler
Old   November 27, 2008, 10:07
Default Fortran compiler
Erik
I have a question about compiling Fortran user subroutines. At the moment, there's an Intel fc80 compiler installed on the cluster. When I want to run a StarCD simulation with user subroutines, prostar returns that it can't find the required Fortran compiler (/opt/absoft/bin/f90). Is it possible to compile the subroutines with the Intel compiler first and give some kind of input from these subroutines to the StarCD problem? Or is it possible to change the location where prostar will look for the Fortran compiler and use the location of the Intel compiler instead?
Thanks in advance!
Old   November 28, 2008, 02:12
Default Re: Fortran compiler
Tom
I think that you have to have absoft fortran. But in answer to your question, check software.ini and hardware.ini. Those are two of the places that the compiler and the path to it is set.
Tom
Old   November 28, 2008, 20:05
TG
For the current version of STAR on x86 architecture you can use either the absoft compiler or the Portland Group compiler but you have to install the version of STAR that is compiled with the same compiler. STAR does not currently have a link to Intel's compiler, although it is being looked at.
Fortran Compiler and example Young CFX 1 March 22, 2011 22:26
fortran compiler yfyap Main CFD Forum 13 March 5, 2006 10:19
Which Fortran compiler? Tony Siemens 6 November 19, 2005 05:44
Fortran Compiler wescher Siemens 2 May 30, 2005 07:29
fortran compiler sankar Siemens 3 January 29, 2005 13:12
