August 26, 2008, 17:23 |
star-ccm+ linux installation..
hi all..
i have some problems with linux installation.. i have installed STAR-CCM+ V3.04. now i can run Star-CCM+ as root.. but i cant as other user.. when i try to create new simulation i got segmentation fault.. what can i do? is there any definition i passed, forgot.. thanks in advance.. |
September 29, 2008, 10:59 |
Re: star-ccm+ linux installation..
You need to configure rsh or better yet, configure ssh and use it instead (everyone will tell you that rsh is insecure). at the end of the command to start star-ccm+ just add "-rsh ssh" without the quotes to use ssh instead of rsh. Once you have done that you should be able to run in parallel. However, you must configure ssh permissions for your user if you want to run it as user. google will help tremendously.
September 30, 2008, 09:50 |
thanks a lot...
Gambit installation under linux | Alex | Main CFD Forum | 1 | December 4, 2008 01:32 |
Linux installation | sunnysun | OpenFOAM Installation | 5 | May 22, 2008 13:24 |
Help with new installation on AMD linux 64 bit | mattijs | OpenFOAM Installation | 7 | September 29, 2005 15:53 |
Installation in a 24 linux kernel | sampaio | OpenFOAM Installation | 0 | July 20, 2005 17:37 |
Who have 3.24 linux help file about installation? | Kevin | Siemens | 1 | July 8, 2005 08:42 |
