star cd 4.06 parallel problem
Old   October 18, 2008, 22:51
Default star cd 4.06 parallel problem
whitemelon
the problem is as follows,
C:\Program Files\CD-adapco\STAR-CD\4.06\bin\star.exe -decompmeth=x -mpi=mpich2 2 PNP: Initialized [2008-10-19-10:46:58] Automatic Sequential Automatic Parallel analyzer. PNP: Allocated "xy,2" resource (2 processes). PNP: Assigned "xy,2" resource to STAR solver (2 processes). PNP: Loading STAR solver dynamic shared object plug-ins. PNP: Loading MPICH2 1.0.6 dynamic shared object plug-ins. PNP: Spawning STAR processes on single node. Credentials for xy rejected connecting to xy Aborting: Unable to connect to xy PNP: Shutdown [2008-10-19-10:47:00] Execution aborted by request (SIGABRT) after 2 seconds (OVERALL ELAPSED TIME).
I have no idea to deal with this problem, who could you give me some advices, thanks.
Old   October 19, 2008, 10:38
Default Re: star cd 4.06 parallel problem
c.duckinson
try to run via the star-shell (help-> star-shell). The starlaunch never works very well. The problem could be differentiated from starlaunch using star-shell.
cheers,
c.
Old   October 20, 2008, 07:58
whitemelon
it also doesn't work well when use the star shell ,the problem is, Administrator@xy ~ $ star -mpi=mpich2 xy,2 PNP: Initialized [2008-10-20-19:52:49] Automatic Sequential Automatic Parallel analyzer. PNP: Allocated "xy,2" resource (2 processes). PNP: Assigned "xy,2" resource to STAR solver (2 processes). PNP: Loading STAR solver dynamic shared object plug-ins. PNP: Loading MPICH2 1.0.6 dynamic shared object plug-ins. PNP: Spawning STAR processes on single node. Credentials for xy rejected connecting to xy Aborting: Unable to connect to xy PNP: Shutdown [2008-10-20-19:52:50] Execution aborted by request (SIGABRT) after 1 seconds (OVERALL ELAPSED TIME).
Old   October 23, 2008, 14:42
george
Please can you tell me what is the name of your uname -n? Did you give the right name? Did you try to run it in xy,1 and it worked? Do you have license for 2 processes? Check starhpdomains and starpar in your license file. xy is one processor with 2 cores?
Cannot run Star-CCM+ parallel in Linux dburns Siemens 9 April 27, 2010 12:01
Parallel Simulation using Star-CCM+ SG Siemens 5 March 11, 2008 10:52
STAR-CD v4.02 parallel problems on Win XP 64 bit Kasper Siemens 3 September 24, 2007 06:06
parallel Star-CD Andy Siemens 1 December 6, 2002 10:11
Parallel STAR version Michael Schmid Siemens 1 November 7, 2001 09:41
