limit for porous alpha and beta coefficients
Old   December 19, 2008, 19:15
Default limit for porous alpha and beta coefficients
Guy
Hi all, Does anyone know if there is a maximum threshold (and what they are) for the alpha and beta coefficients used in the porous baffle assumption. I am using star-ccm+ but I guess the same limits would apply to star-cd; so if anyone knows that would be great.
Old   December 19, 2008, 19:58
Default Re: limit for porous alpha and beta coefficients
asdf
There is no upper and lower limit, what you need to be careful of is having too large a difference between the lowest and highest xyz components of alpha and beta. Star-CCM+ seems to actually be more picky about this... I cannot get away with more than about 3 maybe 4 orders of magnitude difference between the components.
Old   December 21, 2008, 08:25
Default Re: limit for porous alpha and beta coefficients--
Guy
Hi asdf,
Thanks for your kind advice. Just to clarify, do you mean the height of the porous interface? Or do you mean the relative magnitude of the alpha and beta coefficients?
Also in your calculations do you change the porosity coefficient to represent the actual (physical) porosity of your baffle? In my simulations I have assumed that this coefficient is needed when pressure drop data has been obtained from actual velocity instead of superficial velocity, and I have therefore considered the porosity coefficient equals unity; given the fact that cells are 100% open in the CFD sim. Is this justified in your opinion?
Thanks again for your help
Old   December 21, 2008, 10:59
Pauli
The StarCD manuals (methodology/user) explain converting pressure drop to alpha and beta, actual versus superficial velocity, and porosity. It gives guidance regarding relative magnitude & recommends one coefficient (beta?) not be set to zero.
Sorry but it's been a while since I use porosity & don't remember it all off the top of my head.
I don't use CCM+. So I can't comment on what is done in that code.
Viscous resistance coefficients in porous medium fpingqian FLUENT 50 June 26, 2019 01:55
viscous resistance coefficients in Porous media choyong FLUENT 9 December 15, 2014 20:01
porous media resistance coefficients Thiyagarajan FLUENT 5 October 27, 2011 06:24
to calculate alpha and beta Nirmal Siemens 1 November 9, 2005 00:50
Determining alpha and beta for porous baffle Liaqat Khan Siemens 1 October 27, 2000 04:44
