Star CCM+ issue (VOF and Non newtonian power law)
Old   January 22, 2009, 08:06
Default Star CCM+ issue (VOF and Non newtonian power law)
Sam
Hello everyone,
I have an issue with a case: I want to study a bubble injection in a liquid whose viscosity is characterized with the herschel bulkley law (Non newtonian generalized power law in star CCM+). It seems that there are some incompatibilities between VOF and this viscosity model. The simulation won't run and I have this message : "Attempt to access unallocated NonNewtonianViscosity storage in cells in fluid "
I have tested VOF with constant liquid viscosity : it works
And single phase flow with the Non newtonian generalized power law : it also works.
If someone has a solution or is aware of this, it would be great.
Thanks a lot
Sam
Old   January 22, 2009, 17:00
Default Re: Star CCM+ issue (VOF and Non newtonian power l
donald
the best is to specify viscosity through field function. it works ok
Old   January 23, 2009, 03:26
Sam
Oh ok, thank you for your answer !
Now I'll have to the variable name for the strain rate, gonna have a look in the guide, unless you know it ?
Thanks again. Sam
Old   January 23, 2009, 07:39
Sam
I found the solution. Actually the default settings do not provide all the field function. One must activate "Temporary Storage Retained" in the "Solver" "Segregated flows". Then Strain rate variable and other cell gradients can be reached.
Non-Newtonian Power Law for Viscosity John FLUENT 16 September 12, 2015 06:18
CFX non newtonian power law fluid Mehmet SORGUN CFX 4 October 13, 2013 10:25
new parameter for non newtonian power law model! Antoine FLUENT 0 July 21, 2008 04:30
non newtonian power law dana mahfouz FLUENT 0 October 4, 2005 09:21
Non-Newtonian power law fluids Tim Phoenics 0 September 17, 2003 16:08
