BC for Gray S2S Radiation in ccm+
Old   January 19, 2009, 11:16
Default BC for Gray S2S Radiation in ccm+
Kalle
I am modelling Gray Radiation in ccm+. In the domain is a hot wall 1000K which is surrounded by other walls. The question is, do I have to set a temperature boundary condition on the surrounding walls, or is it sufficient enough to set Emissivity and Transmissivity and getting the Temperature as a result? Is the problem then fully constraint? From looking at the ccm+ online help for the radiant flux calculation it is not fully clear to me weather the surface temperature has to be given or not. If i set the other walls adiabatic they still pick up temperature.
Thanks,
Old   January 29, 2009, 15:04
Default Re: BC for Gray S2S Radiation in ccm+
Evan
In order for radiation problems to be fully defined you must have a boundary condition of a heat flux (may be adiabatic) or temperature. The one you input is your BC and you can solve for the other one.
Hope this helps.
Gray Radiation Newbie FLUENT 7 September 18, 2023 00:42
DO radiation method, non-gray band model, UDF wouter Fluent UDF and Scheme Programming 5 March 23, 2017 22:03
about non-gray radiation Brien FLUENT 0 February 23, 2006 04:22
reference for non-gray radiation Nuray Main CFD Forum 1 April 6, 2003 20:47
Gray scale Contoures zahid FLUENT 4 May 31, 2002 03:52
