January 19, 2009, 11:16 |
BC for Gray S2S Radiation in ccm+
I am modelling Gray Radiation in ccm+. In the domain is a hot wall 1000K which is surrounded by other walls. The question is, do I have to set a temperature boundary condition on the surrounding walls, or is it sufficient enough to set Emissivity and Transmissivity and getting the Temperature as a result? Is the problem then fully constraint? From looking at the ccm+ online help for the radiant flux calculation it is not fully clear to me weather the surface temperature has to be given or not. If i set the other walls adiabatic they still pick up temperature. Thanks, |
January 29, 2009, 15:04 |
Re: BC for Gray S2S Radiation in ccm+
In order for radiation problems to be fully defined you must have a boundary condition of a heat flux (may be adiabatic) or temperature. The one you input is your BC and you can solve for the other one.
Hope this helps. |
Gray Radiation | Newbie | FLUENT | 7 | September 18, 2023 00:42 |
DO radiation method, non-gray band model, UDF | wouter | Fluent UDF and Scheme Programming | 5 | March 23, 2017 22:03 |
about non-gray radiation | Brien | FLUENT | 0 | February 23, 2006 04:22 |
reference for non-gray radiation | Nuray | Main CFD Forum | 1 | April 6, 2003 20:47 |
Gray scale Contoures | zahid | FLUENT | 4 | May 31, 2002 03:52 |
