VOF error when initializing
Old   January 21, 2009, 06:33
Default VOF error when initializing
Simone
When initializing turbulent flow for VOF calculation, solver get me this error:
"Warning: Initializing turbulent flow with density unavailable in fluid! Density of 1 kg/m^3 assumed for computing initial turbulence quantities."
What is it?? How can I avoid this error??
Thank a lot
Old   January 21, 2009, 07:12
Default Re: VOF error when initializing
Andrea
There's no problem, simply the turbulent flow field will be initialized using a standard density value. Next the turbulent flow will be calculated coerently with the exact density of the fluid...
It's just the initialization
Old   January 21, 2009, 08:07
Simone
...ok, but after a few iteration simulation diverge and the iso-surface at VOF=0.5 assume unphysical shape....
With laminar model I don't have this problem!
Any idea??
Old   January 21, 2009, 08:19
Andrea
what kind of simulation is? Steady, transient...and also: underelax, boundary, initialization field/functions...?
Old   January 21, 2009, 08:27
Simone
Simulation is VOF unsteady, underelax low (0.4, 0.3 etc..), wov wave first order, 6DOF frozen for computing hyrodynamics forces on a ship hull.
Similarly of the demo from CD-Adapco for DFBI, i set the correct bondary conditions, but i change turbulent model...so from laminar to k-omega. Mesh is ok, with B.L.y+=50.
Time step 0.01s
Do you have any experience on this problem?
Old   January 21, 2009, 13:27
Adam
Are you using first or second order time Discretization?
Old   January 21, 2009, 14:08
Simone
second order
Old   January 21, 2009, 14:09
Simone
and first order for time!
Old   January 21, 2009, 16:00
Adam
Try changing the turbulence specification to K + Epsilon on both the initialization and the inlet.
Old   January 23, 2009, 07:18
Andrea
if it doesn't work try initializing the sim with first order scheme...then switch to second order later
It's a general tip, I'm sorry but I don't have experience in this kind of sim...but the initialization it's similar to other ones...
Old   February 3, 2009, 19:35
  #11
star
Have you tried lowering the time step? Are you using ccm+ or v4? In v3 I always faced problem when the time step is that large (0.01s). In v4 this seems less a problem. I think I read on the manual or somewhere VOF is not yet able with k-omega or other turbulence models. For DFBI, it might not even able to handle k-E but I'm not sure. BTW, I'm curious to know how long it takes you to complete this run.. the elapsed time I mean... when you complete this job later. (Just curious if you dont mind).
Old   February 11, 2009, 11:26
  #12
jimmer
I think VOF and turbulence don't go together in STAR-CD. The software calculates granular variables and the only correct choice there is laminar flow.
error while initializing mahi FLUENT 1 November 26, 2008 05:11
Error while initializing a case summer FLUENT 0 April 15, 2008 16:22
Initializing different block in 3D star123 FLUENT 1 April 8, 2008 20:57
initializing the solution Thiyagarajan FLUENT 2 June 6, 2004 02:48
UDF for initializing VOF Ray Main CFD Forum 0 November 11, 1999 11:29
