License server info- where is it stored?
Old   November 9, 2010, 12:19
Question License server info- where is it stored?
Altocirrus is on a distinguished road
I have just installed Star-CCM+ on my PC. However, during installation I entered one of the license server addresses incorrectly, and (despite re-entering it correctly) it seems to be causing problems. Namely, Star-CCM+ is unable to acquire a license at the start of a new simulation.
I've tried uninstalling and reinstalling, but the license server info is left unchanged. Therefore, I need to find where it is stored in order to edit or delete it. I've looked in the Registry (HKLM\SOFTWARE\FLEXlm License Manager\CDLMD_LICENSE_FILE) and in the Environment Variables, but these locations only hold the three correct license servers. It is the incorrect one which I am unable to locate.
I'd be extremely grateful for any input on this.
Thanks
Altocirrus is offline   Reply With Quote
Old   November 9, 2010, 12:29
Just adding a bit more info if needed- here's the contents of the License Server Information stage during installation:
A scan for license server hints found:
Registry Entries (HKLM\SOFTWARE\FLEXlm License Manager):
CDLMD_LICENSE_FILE= [Valid Server 1];[Valid Server 2];[Valid Server 3]
LM_LICENSE_FILE=
Environment Variables:
LM_LICENSE_FILE=
STARDIR=
A check for server accessability found:
[Valid Server 1] -
[Valid Server 2] -
[Valid Server 3] -
[Incorrect Server] - cannot connect to that port@host configuration
(Obviously I've replaced the actual server addresses)
Thanks
Old   February 21, 2023, 11:45
Hendrik von Schöning
HVonSch is on a distinguished road
In case someone stumbles over this while googling.
On Linux the license sever info is stored in $HOME/.flexlmrc
You can also set the environment variable CDLMD_LICENSE_FILE by prepending, via export or in your bashrc.
Best,
Hendrik
HVonSch is offline   Reply With Quote
fluent license server James FLUENT 3 March 16, 2015 02:50
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Checking license server and batch jobs Ervin FLUENT 0 October 15, 2008 11:52
OpenFOAM with Cygwin kitchener OpenFOAM Installation 6 April 24, 2006 23:09
License server gives problems Karl FLUENT 1 November 27, 2002 05:14
