February 17, 2011, 05:26 |
How handle a anisotropic heat conductivity?
Sven Degner
Rep Power: 17 |
for a cht-Simulation I try to realize a anisotropic conductivity. Normally we got a scalar for this constant. But for anisotropic Materials need a vector or symmTensorfield. I'm really new in ccm+ but not sure where I start with this issues, userCode, field functions? I'm really thankful for any clues? Thanks Sven Last edited by sven82; February 21, 2011 at 04:31. |
February 18, 2011, 04:15 |
Mark Olesen
Rep Power: 40 |
February 18, 2011, 04:31 |
Sven Degner
Rep Power: 17 |
OH sorry,
of course anisotropic conductivity! |
February 26, 2011, 04:27 |
Rep Power: 15 |
You can do it by field function or choose the anisotrop conductivity for your physic continuum.
If you want to do it by an field function, define your field function, click on your physic continuum node --> Air/Solid/Fluid --> Material Properties --> Thermal conductivity. There you can change the settings from constant to field function. Choose your field function...ready. The other way just works for solids, so your physic continuum must be an solid. Go to the material properties of your solid continuum like described above, there you can change your thermal conductivity settings to anisotrop. Now you can define your tensor for every region that uses this solid physic continuum. To do this, go to the region node you want to define, there you find the physics value node --> anistropic thermal conductivity. Efine your tensor...ready. Have fun, Max edit: i forgot to say that this ways can be used by ccm+ Last edited by willimanili; February 26, 2011 at 11:09. |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
