Reverse Flow Problem. (Hull with a Bulbous Bow )Towing Tank simulation.
Old   February 27, 2012, 22:56
Default Reverse Flow Problem. (Hull with a Bulbous Bow )Towing Tank simulation.
Maher Sawaf
Nyarla is on a distinguished road
Hi everyone ..
I am writing here after attempting desperately several times to resolve the reverse flow problem which appears after few iterations.... I set the initial conditions and the boundary conditions (velocity inlet, pressure outlet, symmetry and wall )..6DoF hull body ..VoF wave..multiphase mixture ..etc....everything seems correct but when I use a hull with a bulbous bow the simulation collapses cuz of a reverse flow !...dont understand why ? is it the meshing method !
for meshing i chose the models : Surface Remesher ..Trimmer .. Prism layer mesher..and applied volumetric control with Z axis anisotropic ..repeated the simulations with diff mesh qualities and still hit the same problem ....
any advice will be highly appreciated ..
Nyarla is offline   Reply With Quote
Old   February 29, 2012, 01:30
sanjay's Avatar
aerosapien
sanjay is on a distinguished road
I experiences the same problem after few iterations
regards
www.aerosapien.blogspot.com
sanjay is offline   Reply With Quote
Old   March 13, 2012, 19:04
Default reverse flow fraction
sgrshukla is on a distinguished road
the boundary where reverse flow occurs should be provided with 1 for either fluid. suppose if you provide fraction 1 for water and 0 for air it will only allow water to come in through reverse flow.
sgrshukla is offline   Reply With Quote
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
problem of river flow simulation Liu Main CFD Forum 0 May 27, 2004 22:01
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
Simulation of Two Phase Fluid Flow Problem Using Fluent 5.0 Mohammad Al-Shannag Main CFD Forum 1 July 16, 1999 11:28
Flow patterns in a stirred tank Glenn Price Main CFD Forum 13 March 20, 1999 10:16
