Simulation of Multiphase Heat Exchanger
Old   June 8, 2012, 13:54
Default Simulation of Multiphase Heat Exchanger
Faisal
faisal_ahmed92 is on a distinguished road
Hello all, I've been using Cfx 13 to simulate a heat exchanger simulation, with water flowing through outer chamber taking heat from inner coil, through which acetone flows. Due to heat given to water acetone condenses
My approach to solving:
Define two separate domains, water and acetone zone, and then in the domain interface define a heat exchange with copper of 1mm thickness. Problem is my solver keeps crashing after 3 or 4 iterations with
Floating Point Error : Overflow,
The one time I got a complete run, the CFD post doesn't show any streamlines for the coil domain. Please help, Ive been at it for weeks now!!
faisal_ahmed92 is offline   Reply With Quote
Old   June 10, 2012, 10:12
Faisal
Anybody PLEASSE!! Ive been stuck on this a very long time!!
Old   June 11, 2012, 20:14
http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F
Old   June 12, 2012, 03:06
Faisal
Just wanted to say that you are legend over here!!. Many thanks, I tried using those steps and got a solution, but the problem is the solver doesn't solve for the inner(coil) domain at all. I looked up the condensation tutorial, but that has a mixed gas phase and a liquid phase, whereas i am looking for a gas and a liquid phase in one single domain(coil). Any thoughts?
Old   June 12, 2012, 19:44
I would do some development work with the inner domain only. Run that as a model by itself and see what settings it likes to converge. Then combine that with the full simulation.
Old   June 13, 2012, 03:22
Faisal
I tried doing that for single phase fluids and it worked WITH the outer domain as well, but when I switch to a condensation model (Acetone vapor continous phase and acetone liquid dispersed fluid), the solver just doesnt solve for the inner domain
Old   June 13, 2012, 07:33
Condensation models are tricky multiphase models - so replace the outer domain with a constant temperature wall and work on getting condensation working in that simpler case before coupling it together.
acetone, cfx 13, domain, heat exchanger, multiphase
Continuity convergence issue for a multiphase flow in a counterflow heat exchanger Andrea1984 Fluent Multiphase 2 July 24, 2013 04:55
Macro Heat Exchanger not selecting (Please help!) zdeth FLUENT 2 September 11, 2012 13:52
UDF for Heat Exchanger model francois louw FLUENT 2 July 16, 2010 02:21
Ash/Air multiphase heat exchanger pantarei83 CFX 0 May 20, 2009 08:34
Diesel combustion simulation ( Heat release rate) venkatesh Siemens 2 April 29, 2009 07:38
