June 13, 2012, 03:11 |
Disc brake simulation with solids
Roland Rakos
Rep Power: 17 |
I would like to calculate a disc brake. The disc contains an inner fluid domain.The temperature distribution in the bodies will be the main output of the simulation therefore the solid domains too are included in the CFX modell. The disc are rotating. The modell is quite complicated therefore I would like to complate the analysis in steady state. The inner fluid domain of disc is defined as rotating fluid domain. The disc is defined as rotating solid domain. Finally the outside fluid domain is stationary. The disc and the brake shoe are connected with „solid-solid” interface. A heat source is defined at this interface and I would like to investigate the heat expansion in the disc. Based on results, it can be seen that the fluid domain is rotating but the solid domain (disc) is stationary in spite of my settings. The temperature distribution (in the disc body) shows that the rotating of solid is not occur. What can be the problem? How should I solve this case? Thanks a lot, Best regards Roland |
June 13, 2012, 07:39 |
Rep Power: 143 |
I seem to recall that rotating solid domains was only introduced in V14. If you have an earlier version of CFX you will not be able to do this.
June 13, 2012, 08:36 |
#3 | |
Roland Rakos
Rep Power: 17 |
I am working in 12.1. There is a "Solid Motion" option. What kind of problems can be solved by this option? Perhaps can it help me in this problem? Thanks Roland |
June 13, 2012, 08:38 |
#4 | |
Rep Power: 143 |
June 13, 2012, 08:52 |
Roland Rakos
Rep Power: 17 |
velocity profile export from a simulation onto another | sudhirlv | STAR-CCM+ | 1 | September 12, 2010 18:57 |
Bike brake rotor simulation | gnuboard | CFX | 3 | August 2, 2010 19:02 |
strange simulation error | Ralf Schmidt | FLUENT | 2 | May 4, 2007 13:02 |
Brake Rotor Thermal Calculation in STAR-CD- Urgent | ps | Siemens | 3 | June 27, 2006 04:18 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 10:06 |
