Fan simulation divergence
Old   July 23, 2012, 22:30
Post Fan simulation divergence
Ayothi Ramanathan
ayothicfd is on a distinguished road
Hi everyone,
I am doing FD fan in ansys. I have noticed divergence problem while doing the mass flowrate of 53.54 kg/s and above with IGV 30 deg inclination. I have taken a backup file of the same run while getting diverged in which I have gained some idea that the pressure value at stator-rotor interface is getting too large (around 2 lakh pascal). So that, I have given the interface option as frozen rotor instead stage. And, It is getting converged for the above specified mass flow. I checked the same simulation by changing the interface option as stage through the converged result as initial file. It is also getting diverged and stopped. Is there any problem while doing interface option as stage? or do I have to look any important things before using stage interface?
ayothicfd is offline   Reply With Quote
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 08:24
Divergence detected in Valve simulation mehn STAR-CCM+ 5 July 23, 2009 08:38
Flow Simulation Outlet Fan D.Castle FloEFD, FloWorks & FloTHERM 0 June 30, 2009 15:00
simulation of a fan...plz help pankaj chaddah FLUENT 4 July 13, 2006 12:34
Question concerning about the flow simulation of a fan in an engine room. ghlee Main CFD Forum 3 October 21, 1998 07:05
