Simulating soot sticking to a wall in a boiler flue.
Old   August 5, 2012, 07:16
Default Simulating soot sticking to a wall in a boiler flue.
Yury Timofeyev
Zmur is on a distinguished road
Send a message via Skype™ to Zmur
Hello!
I need to simulate how the boiler flue is being contaminated by soot particles.
I have a model of a boiler, where the hot gases (air and soot) travel through a pipe, which is inside a tank of water (this water then is used for heating). The length of the tube is 1m, diameter is 80mm. It has some obstackles inside it (made of sheet metal, size about 50mm), which are used to increase turbulence. The soot is sticking around them. We try to optimize the flow so that less cleaning is required.
Right now I can't make paticles to stick to wall. They only slide along it.
Some settings:
Particles:
Erosion Model Finnie (power factor = 2.0; Reference Velocity 1 ms)
No Particle rough wall model
One way coupling
Drag Force Schiller Naumann
Particle control settings:
max. part. integr. time step is 1e10[s]
Max tracking time is 20[s], Distance is 10[m], steps 100000
Flow:
Flow velocity is 5m/s (a pump is mounted at the air intake of the device), temperature is 300C.
Heat transfer is enabled. I use Heat transfer coefficient setting on the outer side of the tube. The water outside of the tube is about 70C.
Any information source on the problem would be helpful. Also, I think that I don't need tpo simulate particles precisely. It would be sufficient for me to see where they are gathering and\or sticking to a wall. If there is a way to do this without particle simulation, this may also help.
Zmur is offline   Reply With Quote
Old   August 5, 2012, 08:32
Why are you using an erosion model? I did not think soot could cause erosion.
I think you are looking for the coefficient of restitution parameters, which you set on the wall boundary. You set this to zero and the particles stick.
Old   August 5, 2012, 15:34
Yury Timofeyev
My mistake. Turned that off.
Looks like they now just disappear after hitting a wall. I made parallel restitution coef. 0.9 and perpendicular 0.
Old   August 5, 2012, 19:21
Yes, the particle track stops (ie disappears) after hitting the wall.
Old   August 6, 2012, 01:40
Yury Timofeyev
Can I see how many particles have disappeared in some place?
Old   August 6, 2012, 05:53
Not sure off the top of my head. It might be in the wall volume fraction but I am not sure.
Also, are you sure your particle tracking technique captures the correct physics of soot in close proximity to a wall? Soot is such a fine particle that things like electrostatic charge and possibly other forces will become important which are not usually considered in particle tracking.
Old   August 8, 2012, 15:28
Yury Timofeyev
About that electrostatic charge, thank you, this may be an interesting idea.
Right now I want to find a way to see where particles are concentrating at low speeds (they usually stick to wall in these places). Maybe I can model them as a fluid or some sort?
Old   August 8, 2012, 18:43
My point is a bit deeper than than - soot is such a fine particle it will have essentially no slip relative to the air. This means that it will just follow the air streamlines and not deposit anywhere. But clearly it does, and so something else is happening to the particles to make them stick onto the walls. It could be electrostatics, it could be something else. But something else is playing an important role in deposition and until you include it in your model your model will not be valid.
Following on from this point, if soot has no significant slip relative to air then a particle tracking approach is not a good choice. Modelling the soot as an additional variable with convection and diffusion is more appropriate - it is also much easier.
Old   August 9, 2012, 06:38
Yury Timofeyev
I can try. How can I set this up?
Old   August 9, 2012, 07:25
Have a look at the flow from a circular vent example.
help with wall functions Nick Georgiadis Main CFD Forum 10 January 17, 2017 10:03
Quick Question - Wall Function D.Tandra Main CFD Forum 2 March 16, 2004 04:29
Simple Wall Boundary Conditions for Turb. Flow Greg Perkins Main CFD Forum 4 May 28, 2002 23:10
Wall function in adverse pressure gradients stephane baralon Main CFD Forum 11 September 2, 1999 04:05
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
